juniorhifikit
I found NYDave's balanced LCR switching circuit drawing, and had a question. I'd like to do the same thing, but unbalanced, and am worried about loading the mix bus in weird ways. If I had 15K mix bus resistors for each bus (L & R), but then wanted to assign a channel to both busses, wouldn't I then need 30K resistors in parallel to each bus to keep the load the same? Like this?
http://www.scottgreiner.com/LCR_assgn.jpg
Most drawings I've seen use, say, 10K summing resistors, and then 10K resistors switched in parallel to each buss (to assign to the center) Doesn't this change the load on the mix bus?
Also, should I keep the number of 15K resistors constant on the bus, and thus switch the unassigned points to ground through 15K resistors?
