used as switches, they are probably allright..vactrol's are used in many guitaramps to handle channelswitching duties, but used as a pot is probably harder to do.
As I understand it, they have a "memmory" of what the just where..so going from one set value to another and then back again, might not result in the same actual value, even if everything else is identical. Thats ok for compressors and limmiters, where everything is dynamic anyway, but for a "pot" that is to be left in a sertain position..?..probably not..
I'm just guessing, but that is how I understand it..I'm sure others will fill in the gap's...
johan
