I'm going to hook up 2 white LEDs to act as a 'backlight'. I want to limit them to 10mA. So I'll be using a 700ohm resistor for current limiting (15V source, with 8V of voltage drop [4v for white times 2]).
The question I have is about the Vmax parameter of the LED. How do I work around 5V max volts if I have a 15V supply? Am I going to have a make a voltage divider to step down the 15 to 5. If I do this, the voltage drop is going to be more then supply voltage..... :?
Help!!!
Help!!!
