Lexicon 300 Display Transformer needed
I would like to have these instructions too please!
First off, download a copy of the service manual and schematics, refer to the page on the power supply circuit, read up on VFD driver circuits. Replace all the electrolytic capacitors in the entire power supply. Next, remove the ceramic capacitor between the 35v windings of the small display transformer, it's marked C9 on the board. Next, if your display transformer is not visibly torched to death and crumbling apart, test the windings with a multimeter on continuity. If any of the windings don't pass the beep test, or if the ohm reading for either secondary winding is higher than 100ohms, your transformer is toast. If all the windings test good, replace C9 with a solid quality ceramic or film capacitor with a voltage rating of at least 100v. If one of the windings tests bad, you will have to replace the transformer with two transformers, unless you can wind your own from scratch or rewind the original on new bobbins. I used a Triad Magnetics F36-65 for the center-tapped 36VAC winding, and a Triad Magnetics FS12-090 with the primary winding wired in series to produce as close to 6VAC as I could get. It would up being just under 5VAC. This is not ideal, but I couldn't find any other transformer in my country that would fit inside the 300, alongside another transformer, that produced the right voltage. Do not excede 7VAC for filament winding or you might burn out the VFD. You may want to change diodes CR8 and CR9 in the path of the 35v winding to a diode with a lower voltage drop to get closer to 35VDC. Do not hook the wiring header that feeds the display board from the power supply board to the display board first time you power your 300 back on. Test the voltages coming from whatever solution you try before hooking the display wiring back up to make sure you're getting at least 30VDC and 4.5VAC respectively. The original .06A fuse feeding into the display power circuit should still be fine for this new solution, but if it blows, replace it with no higher than a .1A fuse.
I cannot help you beyond this point unless you're willing to ship your 300 to me and pay me for the labor. This is also a solution I've only been able to test by burn-in for a few weeks now, so I can't vouch for it as a permanent solution. Undertake at your own risk. How you decide to install any replacement transformers will be up to you. If you're not completely comfortable with your skills and knowledge, do not hesitate to take this job to a tech. You can destroy your 300 or harm yourself if you don't take precautions. The way I had to implement this fix was not ideal. I'm working on sourcing smaller transformers with closer voltage ratings that I'll use to develop as close to a drop-in replacement as possible. I'll update this thread when I come up with a better solution, maybe even pre-made boards or a kit you can assemble. It may also be possible to salvage the original transformer if you're versed in how to wind your own. From what I've gathered, if you catch the issue soon enough, it may only be the 35v winding that burns out...
  • 300-Schematics.pdf
    3 MB
Problem solved! Thank's to mumek for his suggestions. I have changed the caps in the psu and reconstructed the display xfmr.
Hera are some pictures
    389.1 KB
    418.7 KB
    505.7 KB
The original xfmr looked in perfect conditions apparently....certainly not dark brown toasted like many I' ve seen...but it was giving bad contact...was functioning only putting some pressure on it! Not a possible solution really!
Hello everyone. Thank you all for posting this information regarding the Lexicon 300.
I have one that I picked up at an auction for $100.00 and it works perfectly except
for a dim display. I am scared to turn it on because of the c9/ transformer issues on this forum.
I will pull it out of the rack and check the transformer and cap. I also have an MPX-1 that I replaced with
an Oled display from mouser and would like to have a backup for the 300 but I cannot find a replacement display.
Thank you all.
Thank you all.
There is no replacement 300 display. It’s a custom job, nothing currently made fits the bill. The display itself should never be a problem, just the transformer. Unplug the 300, test the windings for continuity. If any give an ohm reading that’s too high, the transformer is starting to go. Replace C9 anyway, even if it seems fine.
Thank You mumek. I will also replace the electrolytics in the power supply.
Do you know the specs on them so I can order them ahead since it will be a pain to remove
the 300?
Thanks for your help.
Hello mumek.
With your help, I finally recapped all the electrolytics of the 300 power supply and the small ceramic cap at the display transformer.
Powered up the power supply board without connecting any of the connectors to the boards including the display unit.
I am worried about the voltages at the display connector.
Yellow & Gray: 44.5 VDC (diodes?)
Violet & Violet: 5.1 VAC
Red & Black: 5.1VDC
What do you think?
Thanks for the forum and your help as well.
Hello Folks,
I was able to repair my Lexicon 300 with 2 transformers that were chassis mounted to achieve the 35V & 5v requirements
for the display.
I was able to get 32 Vdc and 6.5vac for Fila A & B.
Both transformers were center tapped on the secondaries.
I also recapped the power supply and other boards as well replacing a total of 26 Caps and 3 diodes.
Thank You mumek and others members for helping me.
Without this forum, it would not be possible.
    2.8 MB
