Get the test cart ( available on Ebay ?), it will save you hours of guessing.
And follow the chapter 5.5 of service manual.
With the test cart, you get the result immdiatly.
I'm having a real hard time getting the drams out. Wick, desoldering gun.... did you guys get them out or did you cut the legs?
Thank again
I went with flux and desoldering gun.I'm having a real hard time getting the drams out. Wick, desoldering gun.... did you guys get them out or did you cut the legs?
Thank again
Thank again
I just forgot that I have the originalA little hint:
take a working DRAM chip and bend its pins a little inwards.
Have your 480 setup so that you can
hear the fault.
Press the working chip down on one
of the suspected DRAM’s.
TAKE CARE aligning pins properly.
You might get some instant noise due
to the rather rude connection.
But if the fault sound goes away, you
have then found the faulty DRAM
so replace it.
If not try the next and so on.
( a situation with more than 1 bad DRAM can of course occure.)
This hint is for a quick fix and has worked for me so many times.
Best thing to swap all chips.
