Lexicon 960L Won't boot
jwhmca
USA
Hi All,
Lexicon 960L
LARC says "NO 960L YET"
No LEDs lighting on the Reverb PCB
Intermittent booting to BIOS, visible with the external monitor port
Power supply seems to be running okay, although there are a few puffed caps.
CD-Rom drive will not eject after a few seconds.
Sound familiar? Any ideas?
Roger that.
The power supply has all of it's correct voltages.
It's basically an ATX supply. Although it's using the "WHITE" -5vdc wire which isn't normal for a ATX supply.
could be cable to the LARC. You can test the LARC by making a plug that connects the TX and RX lines together, not connected to the mainframe.
