Hi guys,
I need your help for a strange issue related to a Lexicon Larc. I got a M300L, I bought it used and thought, as the Larc was good but dirty, to spray air inside the sliders and then spray also a deoxit solution (I mean directly inside... Already did that with many sliders woth no issues). Problem is that after powering it up if all the sliders stay in the lower position the unit doesn't act strange but when I start moving sliders the unit sometimes goes on reset, but more times it automatically changes the values seen on the screen (I mean going from Predelay to Bass multiplier then Size than reverb time...). It is unusable in this way
So today I unsoldered all the faders, unmounted all, gently cleaned the pcb of every fader with IPA and q tips, cleaned the contact as new with Deoxit and soldered again. Same problem.
You think it is related only to sliders?
I hope you can help me and feel my pain
Every help will be much appreciated. Thanks!
