LA_DIY
New member
I'm designing a little 4 track recorder for a senior design project at USC. Things are going pretty smoothly, but I have one problem that seems so simple to fix, but I haven't been able to solve so far.
The input to the ADC that I'm using for this project has to be between GND and +5V. Ideally the audio would use that whole range so that the full dynamic range of the ADC would be used. The problem is, the opamp circuit I'm using outputs a peak to peak voltage of 5V, but its between -2.5V and +2.5V. I just need to offset the voltage be +2.5V and it will work perfectly.
The opamp I'm using is an LF 356 if that helps.
My professor has said its not something to worry about because this class is more about the embedded system design and not the analog electronics, but I was wondering if anyone here had some insight on how to solve this problem since I'm sure its something that must have come up before somewhere (and because I want my little recorder with a 4kHz sampling rate to sound as amazing as possible :wink: ).
Thanks for the help,
Dave
Dave
