Eicen
Active member
Hi there.
I need to do a 8ch DI box, for a live keyboard setup.
I've previously used 8 x OEP A262A2E as a "quick-fix" - as 1:1 just connected directly between jack, and XLR.
But now i would like to re-do it more correctly.
Since i already have the A2E's, i would like to use them again
Would it be possible to adapt Bo Hansens DI to the A2E, instead of the A3E?
Since its a keyboard setup, i assume the signals will be quite strong.
Some signals will come from delay-, or chorus-pedals. Some directly from modern keyboards
Do you think the level from the keys will be to high for the active Bo Hansen design?
Should I consider a passive setup instead ?
There will be a mains inlet in the box anyway, so it would be possible to have "normal" power-rails, instead of phantom-power..
I hope you guys can help me a little here
