Ummmmmm...I am staying away from the nuances of tiny inductances and capacitances inside of a 20K-ish pot at audio frequencies, and the attendant cussing, etc. in this thread <g>
I have in my hand a copy of a "vintage" API 312 app note, probably from the 1970's. No dates found, but it has the Huntington, NY address, which should be a clue to someone who can cross reference API mailing addresses vs. years.
In a chart for selecting the gain resistor between pins 9/10, they clearly show that an OPEN circuit (ie, infinity Ohms) is acceptable for the least amount of gain.
That makes perfect sense since the gain adjust R is in the shunt portion of the negative feedback loop. With infinity there, the 2520 is operating at unity gain, since the circuit is for an non-inverting opamp.
The app note shows a 20K resistor between the output of the 2520 and the inverting input, so a 20K pot "WFO" on the shunt leg will result in 6 dB of gain from the 2520.
If there is any interest, I'll try and scan/post the app note on my website.
As for off-the-shelf pots with reverse log tapers, Digikey is now stocking PEC hot molded carbon pots in a variety of values and tapers. I would suggest a 25K rev. log for this application.
http://dkc3.digikey.com/PDF/T061/1283.pdf
Bri
