D dude24man Well-known member Joined Mar 5, 2009 Messages 148 Jun 25, 2024 #1 Hello, I'm looking for (2) LM301AN. I'm in upstate NY. Thanks Arthur
S sahib Well-known member Joined Aug 19, 2006 Messages 4,003 Location Glasgow - UK Jun 26, 2024 #2 I have plenty but the postage is expensive. If I can send as a large letter it will be around GBP 8.00. Otherwise it will have to go as small parcel and that is around GBP 15.00.
zzzzz Well-known member GDIY Supporter Joined Jan 2, 2021 Messages 194 Location USA Jun 26, 2024 #3 dude24man said: Hello, I'm looking for (2) LM301AN. I'm in upstate NY. Thanks Arthur Click to expand... messaged
D dude24man Well-known member Joined Mar 5, 2009 Messages 148 Jun 26, 2024 #4 Thanks so much everyone. I have 2 coming. Just curious, Is there a direct replacement for these without any compensation. Arthur
doorunrun Well-known member GDIY Supporter Joined Jan 17, 2023 Messages 120 Location Florida Jun 26, 2024 #5 You might want to stock up on some spares if you can't find a good replacement. $2.90 each from Antique Electronic Supply is a pretty good deal. https://www.tubesandmore.com/products/op-amp-as301an-alfa-single-8-pin-dip I purchased some from them for my Ashly SC-50 compressors.
MidnightArrakis Well-known member Joined Sep 25, 2015 Messages 903 Location Hagerstown, MD USA / Earth Jun 26, 2024 #6 Maybe this will work for you!!! They only have 29,259 of the LM301AN IC-chips in-stock!!! Is that enough for you???..... NOTE: The below webpage is merely showing a "generic" IC chip image and -- NOT -- the actual LM301AN IC-chip: https://componentstockers.com/parts/integrated_circuits_ics/linear_ics/onsemi/LM301AN However, the price for these IC's may possibly be too expensive for you as they're priced at 16-cents ($00.16) a piece!!! Need spares??? LM301AN availability at a variety of semiconductor distributors: https://octopart.com/search?q=LM301AN¤cy=USD&specs=0 Hope this helps!!! /
