Locking Crimp Lug Removal?
CJ
GDIY Supporter
California
these lugs are starting to show up in guitar amps with increased frequency, much to the chagrin of anybody who has to remove them in order to remove the circuit board for whatever reason.
and they are tough, stainless steel, so you end up ripping the pc board apart in frustration of you lose your patience,
is there some type method or special needle nose pliers made for removing these offensive monstrosities?
thanks for any help!
    268.5 KB
(sorry if this is a stupid idea...) there's a spray here sold for electronics use, which (I think) is just anhydrous ethanol (ethanol with no water) and propellant. I might try giving the connection a shot of that hoping it will work in the tiny gaps and act as a temporary lube (then wiggle side to side while pulling--making sure the unit is de-energized, first). Or maybe a combo of the above mentioned (some sort of tool to create more of a gap) and the ethanol spray (hoping it slides out). (Faston connector?)
There are a few crude methods on YouTube, the best suggestion I have found is to spread the lugs apart with s small screwdriver or dental pick, then work it loose.
Coming in from the side with a small nail held by a pair of needle nose was one of the videos but the problem with that us that the lugs I was trying to remove were stacked closely together and between a couple of filter caps.
