Viitalahde
[quote author="mhelin"]I would use a high quality cap in series of the tweeter and midrange.[/quote]
I gave some thought to this, and then forgot about it. Let's calculate again..
Assuming 8 ohms loads for mids & tweeters (with the impedance peaks at resonance points taken into accound), a corner frequency at least two octaves below cross-over points is going to be needed.
Tweeter = 47uF to get way below the resonance point
Midrange = 200uF for flat two octaves under 380Hz.
I've got to think of this. In any case, having a capacitor in series with the tweeter is probably not going to be as bad as having a power relay.
[quote author="Gold"]I know it's not in the spirit of the thread but why not just throw caution to the wind and in the unlikely event of catastophic failure buy a new driver.[/quote]
You got a point there. I've never actually heard of failures with UcD modules so I'm really preparing for the very rare case here.
I am going to implement a DC protection circuit that cuts off the rails when DC is detected. This should give a pretty good protection.
Lamps? Fuses? I've understood the sizing is pretty critical, and they're not maintenance free.
