I feel kind of stupid for not knowing the answer to this, but would a too-low polarizing voltage on a condenser capsule cause low output level? The mic in question is an old Sony C38, which is very similar to, if not the same as the C37 FET (manual here:http://www.coutant.org/sonyc37fet/c37fet.pdf). The output is extremely low, but not noticeably distorted.
It runs on battery only, no phantom powering possible. Polarizing voltage is via a DC-DC converter. According to the manual the polarizing voltage can't be checked with a normal voltmeter (though possibly with modern digital multimeters it wouldn't be a problem?)
Am I thinking right that low polarizing voltage could be the source of this problem (not that I'm excluding other possibilities at this point)? Or am I just wrong?
