LTspice tube models - how to create?
ln76d
Gallifrey
I know that some people here use LTspice so mybe someone would like to help me :)
I want to create 6AK5 / EF95 model for microphone circuits simulations.
What i found for now:
http://www.mif.pg.gda.pl/homepages/frank/other/docs/Koren_Tubes.cir
http://www.diyaudio.com/forums/tubes-valves/120196-spice-model-6ak5-wanted.html
http://www.tube-town.de/ttforum/index.php?topic=19590.0
Could someone explain how to make that model or just make it and paste the file here?
You gave links to two models so use one of them.
Click Edit in LTspice and select SPICE Directive and paste this
.Subckt 6AK5 A S G K
+ Params: Ex=1.919796584 Mug=28.62765031 Mus=5.93E+02 Kg1=1241.263033 Kp=87.71075724
+ Kvb=0.001045715 Go=-0.174882604 Kd=5.00E-02 Exd=1.018581504 Exsd=1.106610165
+ C1= -20.45944113 A1=-0.001923837 B1=20.33820425 X1=0.011665792 Y1= 0.000268033 Sr=0.032709138
+ Cgk=4P Cgs=.5P Cga=0.03P Cak=2.8P
* calculate the total space current based on Koren's triode equations,
* but with an equivalent triode plate volatage equal to the pentode Vs + Vp/Mus
En1 n1 0 VALUE={(V(A,K)/Mus+V(S,K))/Kp*LN(1+EXP(Kp*(1/Mug+(V(G,K)-Go)/SQRT(Kvb+(V(A,K)/Mus+V(S,K))**2))))}
Esc sc 0 VALUE={ (PWR(V(n1),Ex)+PWRS(V(n1), Ex))/(Kg1) }
* calculate the plate current capture ratio
Ecr cr 0 Value={If(V(A,K)<=0,0,C1+A1*V(A,K)+B1*((limit(V(A, G),1,1e6)**X1)/(limit(V(S,G),1,1e6)**Y1)))}
* the tentative plate current is total space current multiplied by capture ratio
Ept pt 0 Value={V(sc)*V(cr)}
* calculate the diode line current
Ed d 0 value={Kd*V(A,K)**Exd*V(S,K)**Exsd}
* the actual Plate current is the lesser of pt and d
Ep p 0 value={Min(V(d),V(pt))}
Ga A K value={V(p)}
* calculate the screen current capture ratio
* if Vg <= 0 then the screen gets all the remaining current, otherwise the grid gets some
Escr scr 0 value={Limit(if(V(G,K)>0,1-Sr*V(G,K),1),0,1)}
* screen current is anything not captured by the plate, multiplied by screen capture ratio
Esg sg 0 value={(V(sc)-V(p))*V(scr)}
Gs S K value={V(sg)}
* grid current is anything not captured by the plate or the screen
Gg G K value={V(sc)-v(p)-V(sg)}
* interelectrode capacitances
C1 G K {Cgk}
C2 G S {Cgs}
C3 G A {Cga}
C4 A K {Cak}
.ENDS 6AK5
Then add tetrode from components and give it 6ak5 for value.
You can also save it to a file and then add spice directive .inc yourfile.txt
And remember that spice will lie to you.
