KMB-AUDIO said:Done with both! They are right at home:
I'll hopefully be able to do some recording this week. I'll post some samples if I do.
Potato Cakes said:Pier,
I've decided to go with the Lundahl 1576 based on your recommendation and I'm trying to determine what R21, R22, and C31 should be. The only thing I have been able to come up with is using the value's from Gyraf's G9 preamp, which would be 470K, 1M, and 10u/63F, respectively. Do you know if these would work? If I contact Lundahl, I'm not sure what it is I would ask them about besides a loading resistor. I usually try to do what research I can before I come here to ask questions, but it seems that my lack of knowledge has caught up with me. Any help would be greatly appreciated.
Paul
ppa said:Potato Cakes said:Pier,
Paul
I would suggest you
R21= 120k
C31= 180pF polystyrene or argent mica type
R22= 33k
thanks
best regards
Pier Paolo
ppa said:thanks very much to krcwell
Potato Cakes said:Hello, friends!
So as I am waiting for a pair of T-pad adapter PCBs from CAPI to arrive to finish up my pair of MA1s, I began to think about uses for the DI input since it won't be used on this round of builds, and an LED is a terrible thing to waste. I'm looking over the schematic and I'm thinking about finding away to make the DI button function as a HPF. Coming off of the backside of the input transformer (which is a LL1576) , my thought is to jump pin 6 directly to the DI switch with a capacitor in line and pin 5 to the ground on the DI solder pad. Am I missing something?
Paul
