abecedarian
- Joined
- Jul 17, 2005
- Messages
- 131
Greetings everyone. I have a situation where I need to extend the top box to a higher height than the current height the stand that came with the unit is. The reason is I want to place the top array speaker horizontally instead of the vertical which is the way it comes. I looked at the base subwoofer module to see what connectors it uses to send signal to the top speakers. Attached are the connectors. I need to make a harness to make the connection so I can ditch having to use the stand. What guage wire should I use and what are the names of these connectors? The first pic is the base module’s, the connecting stand’s bottom and top connections and then the top array. I really appreciate and help I can get with this. Thanks in advance!
