kingkorg said:For those who dont get what i expect from a 5000$ mic manufacturing, just look inside any Brauner mic.
1) Here's a +$6000 Brauner:
https://groupdiy.com/index.php?topic=63305.0
$2 extruded side rails
$2-$5 PCB
$5 tube
$0.50 Wima capacitors
$0.10 phillips/vishay resistors
Owner of that exact mic stated it didn't have much character... and proceeded to make modifications.
2) Here's a $3000 Ref C:
https://www.frontendaudio.com/manley-reference-cardioid-microphone/
Same $2 PCB construction, practically identical chassis build, same suspended tube from PCB setup... I'd even go as far as saying the Manley chassis is more expensive (machined rails). Both are clean and well built. Manley uses more parts, and probably takes longer to build (higher labour cost).
So how is that not exactly the same quality as the Brauner?
tldr: if you don't think the Manley is worth 5K, you're kidding yourself thinking Brauner is worth even more.
