madsimilius
Hi, i have a manley vari mu that i bought 3 years ago, when i got it noticed the needle on the vu on one side used more time to go to 0 then the other. It also compressed one less db on one side, and the output was a little lower on that side.
I've changed the tubes and recapped all the caps that was in my Manleys recap kit.
It is still not right!
If i put the input and outputs to the same, and measure the voltage on the xlr outputs the left one shows 1v with max threshold and 0.6-0,7v with min threshold,
and the right one shows 1.2v no comp and 0.6v with comp.
What is wrong here? unbalanced tubes ? tubes not matching? maby some other cap is bad?
Thank you for reading!
