I did a little experimenting, I built a 1/2 wave tube that is resonant at 1000Hz. While working with it, I found I had 10 time more signal if I put the mic in the center, instead of at the end, like the Pop sci author did. Google to the rescue and I discovered there are velocity waves and pressure waves. and they are opposite each other in a resonannt tube. The electret mic I have is a pressure mic, apparently the authors Crystal Cartridge mic was a velocity mic so his 1/2 wave tubes worked. Then I figured a 1/4 wave closed end tube has it's pressure an antinode at the closed end. so I built a 1/4 wave tube with the mic mounted in the closed end. The 1/4 wave closed end tube with the mic at the end had the same output level as a 1/2 wave tube with the mic mounted at the middle of the tube. The problem, each tube will need it's own mic.
I do have a few questions: Is a 1/4 wave closed end resonant tube as directional as an open 1/2 wave tube? Does tube diameter make any difference in amplitude? I don't think so, but, I'm not sure.
