Khron said:Have you tried taking a look what they're connected to? Or at least which "area" of the circuit they're in?
buckethead said:Here's a link with some infos about the MB15, which more or less has the same output stage - those are diy schematics, so beware:
https://github.com/8TN/Marshall-MB15-Bass-Amplifier-Ampli-Basse
You can also reference infos from MG30, or bass 30 schematics, I think they all use the same TDA2050 output stage. The resistors are for HF roll-off of the pwr amp output to keep it from oscillating - you can more or less "guesstimate" values there. The TDA 2050 datasheet proposes 2,2Ohms / 470nF, marshall seems to use something around 2,5-10Ohms / 220nF in their designs.
The question is, if those resistors went up in flames because of their low pwr rating or some other problem. If it's just the low pwr rating then I would probably go a little higher than 1/4W there and mount them with some space to the pcb.
Hope that helps
Best regards,
Mathias
Beware, those resistors only burn out when the amplifier (chip) is oscillating (at high, inaudible frequency)opacheco said:....
Let tme to try to test and change these resistir to the suggested values in that schematic part!
Khron said:I had a bit of a suspicion that four identical(?) resistors would be grouped up like that anywhere else than in a Zobel network on the output of an amplifier. If those got cooked like that, odds are good the amplifier broke into oscillation at some point.
Since uber-extended high frequency response is not necessary in instrument amps, as a preventative measure, I'd also add a capacitor (1nF max, maybe lower) between the TDA's output and the inverting ("minus") input, to roll off some more top end and reduce the chances of oscillation down the road.
buckethead said:one explanation of why those resistors would get really hot and will get hot in the future.
