note that the MA 808 heater circuit could be improved by un-grounding one end and running 100 ohm resistors off each leg to ground or better yet, installing a hum pot to balance the 60 Ha, a welcome addition to any SE amp as hum is a bigger issue than with a push-pull circuit,
here is the Masco MA 17 schematic, grid leak again>
