T
tubejay
Guest
I'm about to try to modify my EQ on my Yamaha PM1000, and I'd really appreciate it if someone could verify my math here before I order some caps. Many people have talked about doing this (myself included) and I don't know of anyone who's actually done it yet. So I'm about to dive in head first, because the EQ on this thing is really pretty silly as is. I'm basing this mainly off of this website:
http://www.krashjones.com/pm1000/#Thoughts_On_Reworking_The_EQ
I'm going to try to make the midrange be as follows:
From 1KHz to 700Hz by changing the caps from .15uf to .27uf film caps
From 2KHz to 1.6KHz by changing the caps from .068uf to .1uf film caps
From 4KHz to 3.2KHz by changing the caps from .033uf to .051uf film caps
From 10KHz to 12KHz by changin the caps from .047uf (C15) to .039uf film caps
Here's the original schematic from the PM 1000 EQ section:
On the schematic the inductors should have all been labeled mH, not Mh.
Here's the full Yamaha PM1000 manual, which has the FULL schematic:
http://home.new.rr.com/lordjimbo/PM1000E_2.pdf
I tried figuring the EQ points out myself by using this website:
http://www.opamplabs.com/cfl.htm
However, I think that because of the resistor inline with the cap and inductor on each band, this isn't working. If anyone could instruct me how to figure this out myself, that would be most helpful. I'd like to put in a band around 350Hz and 7.2KHz on some of the channels as well.
So the big question, does this look about right???
