mutetourettes
Active member
Hi - first post here so go easy on me!
I have a channel from a MAVIS desk circa 1971/2, a Bill Hough design, class A mic preamp (so I'm told).. I'm trying to sort out a trace of the circuit and if possible, actually understand what he's done..
first up, it's using three TI BC384L transistors,which are, as far as i can establish, NPN BJTs in TO92 case. The scraps of indication i could find from the interwebs had this as a to92b with "american" pinout of EBC (viewed from the bottom, flat side up) but drawing the circuit this made no sense (to me) and so I reckon they must be "Japanese" pinout ECB... can anyone confirm this?
with any luck i've attached my first trace of the circuit topology..
can anyone educate me about this circuit, maybe tell me some keywords to look for? I think Q1 and Q2 are a voltage amplifier with negative feedback of bias (and signal?)
and Q3 a common collector current gain stage with emitter load and bias-only feedback to the voltage stage? signal in that feedback loop goes through C3 to ground, right? why doesn't input signalalso just go to ground this way?
i don't really get how the two feedback loops interact around the base/emitter of Q1..
ok so you can tell i'm clueless, just trying to match what i see here to bits and bobs in textbooks and webpages... can anyone give a few pointers so i can learn? Is this a standard or unusual design?
I'll add values when i've got more brain time to devote to colours... especially tant cap colours/polarity...
the input transformer is a 1:3.2 beyerdynamic..
cheers
M
cheers
M
