pucho812
odd one tonight. MCI jh24 calibration and one channel was not working. When in input, it would not pass signal, when playing back from the MRL, it would not register any level with the sync or repro. Any monitoring of the machine worked except for that one channel.
swapped a different set of electronics from a known good channel and the problem stayed in that position. the meter did not register with any set of electronics in any mode. There was no audio happening at all at that position.
so basically on channel was not functioning at all regardless of mode or which set of electronics were in it but all the other performed as one would expect.
