MCI preamp mod ?
2Low
Germany
Hi
Is there any kind of mod for MCI 636 preamps ?
I know there´s a very reasonable replacement card from John Hardy available, but the question is: Do they sound slightly dark because of the preamp design or low quality components ?
greetings
2Low :guinness:
Hi Keith
The manual says :
The pre-amp consists of an LM394 thermally matched transistor pair and operational amplifiers configured in an instrumantation grade differential amplifier. these differential amplifiers convert the balanced input into a single ended output signal
Okay... I think I have a couple of those. -They don't sound "dark" to me, I must say...
Anyhow, assuming it's the ones I have, there's no poor quality components on them that I've seen. Any 'sound' is in the design. You can try swapping chips for your preferred "gucci" alternative, try some additional ceramic local rail bypass caps, but the design will be the same, it will work the same way, and I don;t expect that you'll notice any real difference in performance.
Keith
[quote author="2Low"]Hi
greetings
2Low :guinness:[/quote]
Does anyone have a schematics of this preamp to share? I think I got one of these cards form Seth a long time ago. We did not know how to power it up safely and after looking at it for a while I set it aside as I did not want to blow it up.
Hey
thanks for response !!!
Here is a picture
1,2 MB
and here a pic of the schematics
1,3 MB
:thumb: [/img][/list]
btw ... this is one of the older spare channels
the strips in the console look better ( new ICs, sockets removed )
