sr1200
Wanted to know if anyone had any clue what the deal was with the HN version of the 421. The '5' way switch is not stepped on mine, and is kind of just like a pot, but its not even that. Theres what looks like a carbon element drum suspended between two copper blades with a lock nut on top (that the screw for the body connects to). The part that spins has a small plastic arm connected to it that fits into a notch on the selector switch. The switch does nothing. Anyone have any insight into this? The grease that was in there allowing the element to move was well broken down and felt like old petroleum jelly. I added a touch of new vasoline which made the mechanism move more freely. Wondering if it has to do with the way the internals are wired. Theres no circuit board in mine, just two leads going into the transformer, and 3 leads coming out of the transformer. The blades of this weird mechanism are connected to what seems like the input (2 lead) side of the transformer. I've long lost the serial number plate for mine, but it was well under 1000 if that makes a difference.
