Martin B. Kantola
- Joined
- Jun 24, 2005
- Messages
- 209
How would you do it? Is there a good way? We're not talking power amps, but OP-amps...
Martin
Martin
Absolute level of crossover distortion is highest at high amplitudes; just relative distortion level usually increases with decreasing amplitude, although there might be a point where this changes again.Be sure to check it at low output levels; that's where it usually shows up.
Switch-off-distortion due to finite transistor switching times is indeed a problem with power transistors (at least with standard parts). However I doubt that with todays GHz processes it is a serious IC opamp problem within the audio range. Crossover distortion will increase with frequency nonetheless as loop gain decreases.Crossover distortion will be most apparent at high frequency, because it is related to the transition time from upper and lower devices in class B output.
