Measuring inductors
hodad
ATL
I have one of those cheap LCR/Transistor testers (like this: tester), and when checking inductance across one side of a transformer I get a different reading depending on which pair of the 3 connections on the meter I use. As a f'rinstance, I'll see 2.4 Henries if I'm hooked to 1 & 2, but 3.8 across connections 2 & 3. I'm a little befuddled as to what would cause this difference. The meter, considering its cheapness, has proven pretty useful in other situations, and I can't quite figure out why I'm seeing what I'm seeing here.
What kind of transformer are you trying to measure?
Just a crappy little 600:600 OEP. I've also tried with another small isolation transformer of unknown origin with similar results. Measuring across either primary or secondary produces similar results. I'll probable just build a couple of simple filter circuits & see which value seems best reflected by the behavior I see.
