At this extreme, low base resistance is key.
The 8 Amp part has small base resistance so that it can be hammered to 8A Ic 1.6A Ib (overdriven switch) without huge base voltage.
The BF459 is a video amp. Bandwidth may be limited by Ccb against Rb. Low Rb is a virtue.
> most low noise parts I am familiar with are much higher current gain
The lower 3dB NF resistance is set by roughly Re+Rb. The upper 3dB NF is about hFE higher resistance. The OSR is in the middle. High hFE parts have a wide range of favorable source resistance, reach a very low NF, and may be marketed widely. Low hFE parts have narrower range of optimum source and won't reach really-low NF.
BF459 hFE at 4mA is like 30 to 50. It will give a 3dB NF at 10 ohms and at around 400 ohms. OSR is maybe 60 ohms, NF here is about 1.4dB.
2N5088 specsheet for 100uA shows 3dB NF 1K5-40K, 1dB at 10K; for 30uA shows 2K-1Meg(?) and 0.75dB at 15K. The high hFE part is wider between 3dB NF points and gets closer to zero NF. However I suspect the optimization for high hFE conflicts with low Rb.
Another aspect: both the cited parts have high breakdown voltage. Doping for high breakdown conflicts with doping for high hFE (roughly as square-root of voltage- see A.S. Grove). In practical circuits with small external resistance, low Rb is better than high Rb. holds the leaky junction together longer.
