Phrazemaster
Hi, I just put together a mic cable for a U47 clone. I used Gotham GAC-7 cable.
I noted after putting it together that the thicker wires had .4R through the cable (about 20' length), but the audio signal-bearing thinner wires measured 1R. The ground and shield were only at .2R (I combined them on the advice of a pro).
Anyway, should I be concerned at the 1R across the audio cables? The wires look to be about 24 or 26AWG. It just seemed like a big loss, but each of the smaller wires incurred the same loss so I'm pretty sure it isn't bad soldering or connections.
Mike
PS hope this is the right forum for this; it is a valve mic!
Mike
