NewYorkDave
TK: Why use one tube?
Lower replacement cost.
Lower noise from fewer stages.
Reliability through simplicity (50% less chance of a tube failure!).
Less power required.
An output transformer is a one-time expense. And if your load is high-Z like the input of most DAWs, you don't even really need one. My One-Bottle does 50+ dB into a high-Z load, 40+ dB into low-Z via a stepdown transformer. Are you guys all recording hummingbirds through ribbon mics or somethin'? Everyone seems to have this mania for more gain.
Really, +40dB is fine for a general-purpose mic preamp, anything more is gravy. The inputs of most recorders have enough gain to compensate for most situations.
If one tube will do the job, then I say do it! If not, use two :wink:
