So I'm tinkering with filters and boost circuits at the moment and ran into something curious (well, curious to me). I have a textbook, low-Q midboost with a fixed 6dB of gain at 1kHz (pic attached) build around two sections of a TL074; one for the inverting boost, the other an inverting, unity gain amp. The circuit is switched into place with a relay. Right before this circuit, there are a switchable second-order HPF and LPF filters, each using another section of TL074. This is running on a single 30V rail, btw.
Both filter sections function perfectly, but something odd happens when I put the mid-boost in the chain: the sine wave I'm using for a test signal suddenly drops in level by about 50% and the positive crest is sliced off at about a 45º angle - this happens to the signal at the INPUT of the circuit. I assume this is some kind of loading effect caused by the mid-boost circuit.
I ran a sim in LT Spice and everything looked kosher, thus my surprise. Should I maybe move that inverting buffer from the output of the mid-boost and put it before?
