mixbus
Member
Hi All,
I hope you can help. I’m working with a friend on an old Midas TR-04 Theater console from around 1980.
He’s having issues with the TR22 Com module.
PFL isn’t working. It includes the solo, mono, dim, and mute.
Parts of the Oscillator section, including the external out on the front of the desk doesn’t work either.
There seems to have been a mod with multiple resistors done at some point just to the right of the edge connector, that is unhooked on the other end, and that part of the desk isn’t working.
He doesn’t know what the mod was for, or what should be changed back. There were some traces cut also.
Attached are the schematics and somepics of the modules.
There are three boards on the module - TR22D is the main board for the channel, an Intercom board, and an Oscillator board.
There are white & black wires in question, that go under or to the back of the modules. There is also a resistor with one leg detached.
A description from him…
“I’m still not sure where the white taped wire goes but I’d guess the 2 wires that are looped with the foam go to T and U. And the resistor cluster doesn’t at all belong and the 2 cut traces can easily be fixed. I’d guess if I took off the cluster and unhooked the black and white mod wires, hooked up T and U wires, and bridged those 2 traces back together, it just may be back to stock. Just a guess…”
I know it's a lot to take in at once! Any guidance you can give him would be helpful. I can get more pics if needed.
Channel TR22D circuit board - near contraption.jpeg160.7 KB
channel TR22D circuit board -mid way -close up of contraption-01.jpeg157.1 KB
channel TR22D circuit board looking up channel to top-close up of contraption-01.jpeg143.4 KB
channel TR22D circuit board-close up of contraption-01.jpeg178 KB
Midas TR22 CCT.PDF4.6 MB
Midas TR22 MAS 282 CCT and Overlay angle projection.PDF9.4 MB
Middle of channel.jpeg458.4 KB
Oscillator board removed-Shows Intercom board .jpeg404.2 KB
Oscillator board-white wire.jpeg141.5 KB
Peek Under Intercom board-2.jpeg114.8 KB
Peek Under Intercom board.jpeg283.5 KB
Side 01_01.jpeg113.4 KB
Side view of end of oscillator-intercom-and main board.jpeg137.2 KB
Three boards-TR22-D-Oscillator-Intercom.jpeg102.3 KB
TR Oscillator board - missing IC2.jpeg172.7 KB
TR22 channel circuit board End of channel - contraption overview.jpeg456.7 KB
TR22 channel circuit board top of channel.jpeg451.2 KB
TR22 channel circuit overview 01.jpeg484.7 KB
TR22 Oscillator Aux Group.jpeg43.7 KB
TR22_PFL routing.jpeg44.1 KB
TR22D backside_01.jpeg108 KB
TR22D Close up of where Oscillator board attaches.jpeg223.1 KB
7CF20F0D-9D3D-424A-A3E1-DDA6E09B63CD.jpeg152.1 KB
16CD91F4-99F3-47A7-A662-53FA63333492.jpeg143.4 KB
