sonolink
Hello to everyone,
I would appreciate your help and advice on the following matter please:
I bought 8 stereo modules (XL304) and a VCA Faders module (XL302) from a Midas XL3. I also have a couple power supply modules.
I've been studying the service manual and the diagrams (attached) but I have a few doubts and would like to make sure I don't fry anything. What I'd like to do is to rack everything up and add a master output. The doubts I have are mainly about some connections.
Please could you check if the following is correct?
-Component side is L channel, solder side is R channel on each stereo module.
Connector A:
1-power ground (+18vdc)
2-iref. What's this??
3- +18vdc
4- power ground (-18vdc)
5- -18vdc
6- 48vdc positive pin
7- Input A hot (from mic xlrf pin 2 input connector)
8- Input A cold (from mic xlrf pin 3 input connector)
9- input shield (from mic xlrf and line jack shield input connector)
10- Input B hot (from line jack tip input connector)
11- Input B cold (from line jack ring input connector)
12- Direct out R ch hot (to direct out jack tip output connector)
13- L ch insert send hot (to jack tip insert send connector)
14- L ch insert send cold (to jack ring insert send connector)
15- L ch insert return hot (to jack tip insert return connector)
16- L ch insert return cold (to jack ring insert return connector)
17- Direct out L ch hot (to direct out jack tip output connector)
18- In gnd. Which gnd is that?
19- R ch insert send hot (to jack tip insert send connector)
20- R ch insert send cold (to jack ring insert send connector)
21- R ch insert return hot (to jack tip insert return connector)
22- R ch insert return cold (to jack ring insert return connector)
Is all this correct? Do you know what connects to pins 2 and 18?
Where are the insert and direct out grounds?
I would appreciate your help very much. Thank you for your time and help
Schematic: https://www.dropbox.com/s/fqzpp1tn6ug3jfm/midas_xl3.pdf
Sonolink
Connector A:
3- +18vdc
5- -18vdc
Sonolink
