Mix Buzz Internal Crush-N-Blend Add-on Board
Bobby Baird
GDIY Supporter
Austin, TX
This is the support thread for the IJ Research designed internal mix circuit add-on board. Originally designed for "Mixbuzz1" bus compressor as an optional dry wet mix. Later it was going to be implemented for the "Mixbuzz 500" as a modular add-on board, but never completed. I decided to finish the original modular idea Igor had envisioned. Here we have the Mix BuZZ Crush-N-Blend Add-on Board. Board measures 89.408mm x 114.3mm.
You can find boards here: Addon: Crush N Blend PCB for the SSL 4000 Compressor, 15,00 €
    175.6 KB
This should work for GSSL
Does this schematic wiring layout come from Living note's Crush N blend rev 6 or Igor's version ?
In fact I've installed years ago the Living Note's version into my GSSL, and remember wiring it up exactly this way. But I had an issue that I've never been able to fix up... Right channel is 6db louder than Left one when C N B engaged. So I was wondering if swapping my version with Igor's one could solve my issue...
This circuit is simple. Basically an unbalanced internal linear cross-fader. One would just need to insert in any processor after the first de-balancing stage and before the final balancing stage. Refer to this schematic for the original implementation. The main difference between the mix buzz compressor and GSSL. The Gyraf version has 2 NE5532 to balance the signal at the output, whereas the mix buzz has a balanced line driver.
    129.8 KB
Hi everyone. I tend to try not to ask/cry for help whenever I can, but I might be missing something here.
I've build 2 Mixbuzz500 recently with success. One with the CnB, the other one without it. They both compress and sound really great by themselves. I only have a problem with the CnB addons.
When engaged, only dry signal come through.
I've check :
- Resistors values - all good
- Capacitors value and direction - all good
- Diode value and direction - all good
- Relay type and switching - all good, they switch when the spdt is on, all working properly according to the schematic
- Omeg Dual gang 10k lin is used here. Working properly (reading 9k20 and 9k60) Wiring is good (no PAN effect, just plain silence, or dry sound)
For tension :
IC 1 & 2 both receive +16v on pin 8 and -16v on pin 4 - all good.
Relays receive +12v from U1 - all good
I've checked for shorts, I couldn't find any.
SJ1 and SJ2 are NOT connected on this unit.
In other words, I'm stuck, and I hate not understanding why it's not working. Must be something stupid simple, but I can't see it. If anyone has any idea, I'd take it. Thanks.
Here's some pics. I put links on the CnB board. Small white wire on CNB1&2_Ch.1 outer terminals. Then link CNB1&2_Ch.2 there is a small black wire that is hard to see in the picture. Link those outside terminals together.
    1.5 MB
    1.7 MB
    1.6 MB
Pay attention to the signal flow through the SJ2, SJ1, CNB1, CNB2, CNB3, & CNB4 points with the Add-on in Circuit.
That's it. When you think you can read a schematic and just go over it thinking you got it....
Thanks Bobby, it works perfectly. I love this place.
