Please note that LTspice reads "2Meg2" as "2Meg". You need to write 2.2Meg.dogears said:Seems to work for me.
It can make a significant difference for 1k8.
Is that a "true VU" meter (expensive), or a mA meter labeled with VU scale? (I'm sorry if this has already been discussed).JAY X said:Hi!
Attached are the schematics of a signal present/peak led. And a vumeter buffer with balanced input and peak led.
Jay x
There are two issues 1) ballistics and 2) frequency response.JAY X said:Hi!
The vumeter is of the cheap ones from JLM audio.
The vu buffer is not tested, sorry, I will try this week ASAP.
The other circuits, the signal present/peak, I have simulated them and seem to work.
Also I have simulated the peak led driver next to the vumeter drivers.
Nothing built yet... :
Jay x
No. The NFB loop is completed via the diodes and meter.mskeete said:Do you have two resistors missing? In parallel with C253/C258
If you have changed the design perhaps share a schematic of your current design.JAY X said:Hi!
I have breadboarded the circuits. The Vu buffer with peak led, works well, although i opted for a different design with the diodes attached at the vumeter, and not in the feedback path.
The signal present/peak circuit doesn't work. With a TLO72, its output seems to latch up, and the leds remain light up....
At the output of the rectifier i measured -2.7v dc, while playing some music through.
I replaced the TLO72 for an OP275, the leds didn't light up with or without signal.
Maybe the rectifier design is not adequate. If there is another one i can build, please let me know...
Both IC are feed with +17v for LM339, and +/-17v for TL072.
I changed the values for the Lm339 resistor divider: 20k /620R/130R. to get the threshold voltages:
0.109vdc for -20dbu
and 0.615vdc for -2dbu.
Jay x
Don't see an input ground connection for audio inputs.JAY X said:Hi!
Attached is the pdf with the new schematics.
The Vumeter and peak led works well. The signal present/peak led does not work.
Jay x
Which circuit are you talking about? If it's the first on top of the page, it should work. If you have negative voltage at the rectifier's output, you may have reverse-connected the diodes...JAY X said:Hi!
At the output of the rectifier caps, i get negative DC voltages. The rectifier works. But as the voltages are negative, and threshold voltages positive, the leds never light up... ???
abbey road d enfer said:Which circuit are you talking about? If it's the first on top of the page, it should work. If you have negative voltage at the rectifier's output, you may have reverse-connected the diodes...
It should be easy to troubleshoot with a VOM...JAY X said:Hi,
The schematic i posted at reply#29.
Anyway i will check again the diodes...
Its always the last thing you checked....JAY X said:Hi!,
Finally It works! A power connection at opamp was missing... :
Nerves are bad companions...
Now i have to adjust threshold voltages.
Jay x
If your measurements are accurate and everything is connected per the schematic, Ohms law instructs us that 3.3mA of current is flowing in R1.JAY X said:Hi!
Despite the circuits worked on the test board, after building the pcb i had some problems. Most are solved, but i still have problems with the two transistor peak led circuit. The led lights up without signal being present. (the leds are in the correct orientation).
I Made some measurements.:
At R1 (4k7), after the 2u2 C1 cap, I measured -0.85v dc and -16.5v at the base of Q1.
not sure which LEDs...At the leds: -0.54v Anode, -0.74v Cathode. with respect to gnd.
The input resistors values are: 4k7/470R. this gives a ratio of : 10 x 0.6 = 6volts.
With other ratios the behaviour is the same.: 4k7/2k2 : 2.13 x 0.6 = 1.28volts
I checked the board for any trace or bad solder...
I also pulled out the 2u2 input capacitors, then the leds did not light up.
Jay x
