Mixer Mic/Line input switch
mikeyB
Manchester UK
Got a Mackie 1640i which has combined Mic/Jk input stage that i am constantly swapping cables.
I want to make a little switch panel that sits at the top of the mixer, using 4 pole Double throw switches.
Attached diagram shows how i would wire the switches. I'm just wondering if i should terminate the ''unconnected''
lines with resistors X and Y to stop the leads acting as ariels. They are only about 40cm in length but will pass over
the in built SMPS. What values would I use for the termination resistors?
As always, thanks in advance
Mike
  • Mixer input mic:line switch.png
    779.5 KB
4 pole double throw switch now outlined in green - poles on the RHS
Solid lines in the switch show mic position and dashed lines show the line position
    780.1 KB
