Thnx for replies, guys.
In the meantime, I'm banging my head against the wall. Quite sad is my state right now....ehhh.
I suspect my problem is not a single thing, but more things combined.
Yesterday I changed four ICS back to 072, and got stability with my improvised (underpowered, original) power supply. I couldn't use it long, because it has small toroid, which gets dangerously hot after some minutes. But it run stable. Improvised PS was cca 0.5m from mixer, in empty mixer frame of second identical mixer (i combined two mixers into one, one was for spare parts...). Then I switched back to my fancy DIY PS, and oscillation was there again.
So I suspect power supply to encourage oscillations at least to some degree.
My fancy DIY PS is made like this:
1. TX: External box with toroid, rectifier diodes and 4x10000uF smoothing caps, to get DC.
2. Ground: From inbetween smoothing caps I have connected four thick ground cables cca 3m long - those go to mixer ribbon cable for all 4 separate mixer grounds.
3. Voltage: In addition I have 3 wire cable going from TX box to rectifier modules inside mixer. This cable is also 3 m long, and carries +/- 26volts, and ground for reference to rectifiers.
4. Mixer: inside mixer I have 8 boards with 317/337 rectifiers. Each rectifier board feeds 4 channels, master and monitor modules with +/- 17V.
Something must be wrong with this scheme. Today I measeured with scope between end points of ground wires. I have the following:
1. TX box 4x10000uF centre point <-> mixer rectifier boards oV reference == 100mVpp @ 1.8MHz
2. TX box 4x10000uF centre point <-> mixer ground 0A == 350mVpp @ 1.8mHz
3. TX box 4x10000uF centre point <-> other 3 grounds (0in, 0P, 0F) = cca 100-150mVpp @ 1.8MHz
I cannot succesfully tie IC power rails to grounds, because grounds themselves are dancing arround. Are ground cables too long? I fear that if I redo all channels bypassing, I will achieve nothing. I tried it with short cable to ground and 330nF capacitor on end, hoping to achieve even slight improvement, touching rails and IC legs, ribon cable contacts, other grounds, but no effect. Shouldn't it be so, that with such capacitor at one point I should hit a point, where oscillation changes, decreases or even goes away?
I think first I should move external transformer as close as possible to mixer. In my mind this would reduce groud lines resistance, and reduce oscillation in grounds. It should also help with noise, isn't it? Because with this DIY PS I have noise spectrum rising at high Freq, like hi shelf filter +20dB would be appliet to noise above 5kHz. With original underpowered PS i didn't have that.
But shouldn't remote PS scheme work fine? I know mixers have long cables for PS, Neve has 20 meters limit.... Those mixers thus also have long ground lines. Is my mistake that I have just transformer far, and rectifiers close to mixer boards? Should rectifiers be close to rectifier smoothing caps and TX?
I've seen some mixer PS schematics, and usually rectifiers are external too, in the same box with TX, rectifiers and smoothing caps. Then clean DC is going over meters of cable to mixer.
This is not practical in my case, because I have 8 boards, that would be plenty of PS cabling.
In any case, I will need to rethink grounding and power scheme, it seems. Also i will have to do something about local bypassing of all ICs, so that all rails are locally bypassed also to ground, instead of one into another, as I have it now. I need to order capacitors, 100nF multilayer ceramics, box is empty atm.
I need to do some thinking about it. Any suggestions, please shoot. Does my PS scheme seem fine, with external TX and internal multiple regulators? If yes, where do I take reference for grounds from? From remote TX box between smoothing caps? Or from internal regulator boards?
