k brown
Just for grins, I picked up a Phonic AM440 compact mixer on eBay (crazy amount of functionality in such a small package - except for not having EQ on the line inputs, pretty much same features as a Mackie 1202 in a package almost half the size); no power supply, but all it is is a 14-0-14vAC trafo, so I cobbled a supply from a Jameco transformer.
No, it's not one of the USB models.
Mixer works flawlessly and is dead quiet, except for considerable hum from the mic inputs when phantom power is on. The pres themselves are fine; silent when an external phantom supply is used, or with a battery electret mic, or a dynamic.
I figured the most likely cause would be bad caps in the phantom supply, but after changing the two output filter caps in the phantom supply, no change. Bad diodes?
Haven't found the schem online.
