mk47 b+ voltage jump ?
wolcott
Member
I have 2 mk47 mics , one has developed an intermittent crackling noise  that happens regardless of different tubes or capsules . My 1.5k drop resistor tests fine out of circuit .
My quiet mike is at 105 B+
My noisy mic is at 106.5 B+ same psu .
Ive cleaned the HI Z section Well . Ive been scouring the build thread for Ideas .
Any other thoughts ? :-\
What is the wattage of your 1.5K drop down resistor and is it aluminum heatsink or cast sand type?
Hey Guys , thanks for the replies .
The problem started with the original kit components , I then swapped out the
drop resistor for a larger sandbar type .
the mic that is quiet is still all original
