rrowley said:Hi All
The problem I have is that in cardioid both front and back of the capsule are on,although the back is duller sounding.If I switch to omni the sound becomes quieter and really thin sounding,again both front and back are on.
bobine said:rrowley said:Hi All
With mine (same setup), in cardioid, the sound from the front is good (uh, great) and the sound from the back is not good (kind of ugly sounding; certainly duller.) In omni, the overall level is lower and the sound is different, less vivid (partly because it is quieter, partly because there is more room in the sound.) I wouldn't say it is "really thin" but I could understand saying it sounds thinner compared to cardioid.
I can't tell for sure, but it sounds like your mic is behaving like mine is. It sounds so amazing in cardioid that I haven't questioned the rest.
The Frizzle said:Do you think it would fit in this case?:
http://www.musik-service.de/mxl-550--551-set-prx395772760de.aspx
Its just 89€ which is like 127$.
But maybe this one is even too cheap and has plastik parts or something?
I like the look tho.
gemini86 said:in cardioid your back diaphragm is disconnected, off. So you're still listening to the front diaphragm, even though you're yelling at the back of it's head.
The Frizzle said:thanks duy_hoang, right your case looks better.
But actually i was thinking of mounting the MK47 inside of the MXL 550 body
I'm just not sure if it will fit.
How do you come to this conclution? Did you try to disconnect the diaphragm on the back and compare?rrowley said:problem is the back seems to be on in cardioid.
rrowley said:In omni the pattern voltage drops from 48v to 30 volts but if I reverse the the front and back capsule wires I have the same problem but without the voltage drop.The relay checks out fine and all other voltages in the mic are are good.
Sredna said:How do you come to this conclution? Did you try to disconnect the diaphragm on the back and compare?rrowley said:problem is the back seems to be on in cardioid.
You mean that the junction between the 14kOhm and 12kOhm resistor in the PSU have 48 Volt?
It should be normal that the voltage drop when you apply a load (relay)...
Not normal is that there's no drop when you rewire your capsule, probably miswiring, check with the step by step instructions.
Hi,living sounds said:Does anyone else have the problem with the SVT-700 and similar mic bodies that the capsule sits too high, just behind the metal ring surrounding the mic basket? This is already the case with the chinese capsule, and the Beez Neez one will be at the same position. There's no room to lower the base, so the only remedy I see is to saw away the ring...
kante1603 said:Hi,
not sure if you meant the SCT-700 (Thomann)?
If so I was able to lower it by using a different holder (used the Thiersch capsule) bringing it about 6mm down.It nearly touched the top of the basket.Not perfect but much better than with the normal holder.Will give it a listen when my psu is done.
Udo.
JW said:Hey guys, Is this sound indicative of bad tubes, or a dirty capsule/high impedance area or something else? http://www.supload.com/listen?s=pSLcIC
Would someone be so kind as to help me figure out which pins on the Binder connector for my EQU47 mic shell connect to what on the MK47 board, specifically?
....problem with the SVT-700 and similar mic bodies that the capsule sits too high, just behind the metal ring surrounding the mic basket?
Sredna said:Dont forget that the U47 got the same (or similar) arrangement with the upper part of the capsule behind the ring. Maybe it's part of the sound!
