living sounds
Try if you can lower the noise by shielding the plug micside with your hands. I had this problem and solved it with a lot of wire wound around the end of the mic cable.
living sounds said:Try if you can lower the noise by shielding the plug micside with your hands. I had this problem and solved it with a lot of wire wound around the end of the mic cable.
crackerzot said:living sounds said:Try if you can lower the noise by shielding the plug micside with your hands. I had this problem and solved it with a lot of wire wound around the end of the mic cable.
This made no difference. The noise I'm getting is very, very hard to hear and basically buried in the noise floor, but it's there and I need to address it. I'm thinking it just might be one of the tubes.
Hmmm...the pic is very dark,I can´t see much,but all of the ac wires including audio should be twisted and shortened to a propper length.Untwisted ac wires will generate magetic fields which can then be picked up by the audio wires;you feed this into a high gain circuit (your mic pre).You´ll notice this as hum.crackerzot said:I've isolated the noise to the P/S. When I unplug the mic, I can still hear the hum/buzz/whatever at a very low level. It might be the orientation of the toroidal transformer or it could be something else. My friend who built it for me is going to troubleshoot and fix it. Glad it isn't the mic!
You´re welcome.crackerzot said:Thanks very much for that info.
I haven´t heard of why not to use starquad-maybe I missed something here,but I´m too lazy to search at the moment.JW said:Can someone theorize on why not to use Canare star quad cable? The 4 conductors are 22awg copper. And the shield has a very tight braid. What is the reasoning for needing an extra ground wire?
Yes,but this is dc current-if there´s no ripple then there´s nothing to inject to the audio.gemini86 said:You've run all the current THROUGH the shield, which could be injected into your audio.
kante1603 said:I haven´t heard of why not to use starquad-maybe I missed something here,but I´m too lazy to search at the moment.JW said:Can someone theorize on why not to use Canare star quad cable? The 4 conductors are 22awg copper. And the shield has a very tight braid. What is the reasoning for needing an extra ground wire?
I have heard somewhere arround here that somebody uses starquad.
Will give it a try on my build as I have a big spool of Gotham Audio Starquad cable.
I don´t see a reason for an extra ground wire as-looking at the schemos and on the pcb-the ground has direct connection to 0v and the microphone-housing via the mounting rails.
Compared this to my original SM69´s psu some minutes ago.The audio grounds,the psu´s 0v and the backplate(where the connectors go)-so the chassis- definetely connect to each other at one screw as to the mic-housing.
Still waiting for my frontpanels so I can´t tell if this works at the moment,but I´m pretty shure it will .
Someone here mounted the pcb with cable ties-this can cause problems if no ground-wire runs/connects to the mic body.
Even if running a seperate wire for grounding:what to do with the cable screen?It must connect somewhere and this will be the chassis ground connected to 0v and so forth....if it doesn´t connect anywhere it is useless.
And something else.In a phantom powered mic the current runs through the shield too!
Udo.
Strange-I hear the background noise and what you describe as "windy",don´t know what that is :'(Andy Meyer said:Here is a link to a sound file of my problem. The first part is the mic in Cardioid. The second part is omni.
http://www.ziddu.com/download/14725165/U47NoiseTest.wav.html
