wave
I've been thinking about your solder issue and maybe the heat is being dissipated down the wire into the coil of the transformer. What wattage/heat are you soldering at generally?
You are wiring it correctly and if you saw the lamp light then it was working. You should def measure it and check the voltage. If you do have 6.3VAC at the secondary, maybe somehow the actual bulb went bad? Do you have any extras?
Just have to figure out why the solder isn't taking. I'm sure you can use some small crimp ends and solder those to the lap housing
Dave
Dave
