EvLoutonian
- Joined
- Jul 8, 2010
- Messages
- 198
Thanks Max!
Treelady said:This is with a dummy load attached, using a Zayance PC board.
I'm located in the US.
I used the TRIAD VPT230-110 wired on the primary/input side in SERIES. Maybe I should have wired it in parallel??
for the Choke I used: TRIAD C-3X Choke
jrasia said:The PSU (Scott Hamptone) is wired as follows. Pins 3 + 4 are common ground. Shield also goes there from the connector.
1. audio+
2. audio-
3. Ground
4. Ground
5. +105vdc @ 50mA
6. Pattern
I wired my cable as follows:
XLR TUCHEL
1 (A+) ---------------------- 1 (A+)
2 (A-) ----------------------- 2 (A-)
3 empty 3
4 (B-) --------blue---------- 4 (B-)
5 (B+) --------red ---------- 5 (B+)
6 (P) ------------------------- 6 (48v pattern)
Tab -----Cable Shield-------- 7 --- Bridged to Tab
Then inside the microphone on the male 7 pin binder I have the shield bridged to pin 4. Pin 4 is then bridged to the mic rail. Though, I'd like to confirm the wiring on the cable first before looking at the male binder.
EvLoutonian said:Thanks for confirming this, Dave.
Would I be stretching the laws of reality in then thinking that perhaps, in this case, if I also had another U47 clone mic, but based around an EF80 tube (which additionally requires approx 6v. filament heater voltage) that I should select this unused pin for the filament voltage, making it safer if I should accidentally plug the wrong mic into the wrong supply?
Presumably the audio pins and B+ pins would be compatible between these two mic's I intend to build, but the heater voltage is a separate requirement on the EF80 circuit, and the 48v. pattern switch on the MK47 is something else I'd need to look at, as the EF80 circuit may simply have a mechanical switch on board, or alternatively variable pattern voltage supplied from the PSU. So that's another thing to figure out what can be done.
I'm trying to think of a safe way to connect my cables up, in the (hopefully unlikely) event of this mis-match between PSU and mic happening, maybe something will not work quite right, but basically nothing dangerous or bad will happen.
I do intend to make both an EF80 type mic, based on the AMI circuit, as well as my MK47 - both using Skylar's Equinox body kit, and each will have the same Binder 7 pin connector at the base, so it's a real concern.
Has anyone encountered this same situation?
I'm hoping there's a way to connect up my pins on each supply / cable / mic, so that nothing would get damaged in the case of myself (or anyone else) getting this mixed up. I'm not sure if there's enough pins available to achieve this, though. Am I dreaming?
electrisizer said:hello there,
ive used the mk47 in different productions till now and really like what it does! espacially on male voices this mik shines...
theres one thing i would like to change. it has not very much highs! even if the highs sound good and smooth when eq is boosting the dedicated frequencies (in contrast to most cheap miks)... i would like to have the highs right there after recording
is there a resistor determining the highs in this circuit???
electrisizer said:ive used the mk47 in different productions till now and really like what it does! espacially on male voices this mik shines...
