ioaudio
looks fine.
Kathode said:I will start building this kit and psu next days and i own to telefunken 6922. Is it possible to use them, or to mod the kit?
JamesW said:PSU gut shot
wave said:Here is a pic of my wiring ...
If it helps you then that is my goal!
The Frizzle said:My Question is: Can i put a resistor in parallel to the pot so half the current flows through the resistor and i don't need 5W anymore?
I need 325 Ohm to get 105V, so i would use a 680 Ohm Resistor in parallel to the pot which then needs to have 623 Ohm.
So I'll have 680 Ohm with 623 Ohm in parallel.
baol said:Hi all you guys, I finished today to assemble my mk47 and psu well... I have 105v on the ouput but when I connect the mic there's no signsl at all, just a few pop sometime. Any idea of what to check again? thank you a million.
Andrea
