Dazazone
Hey max I tried to email u last week about grabbing one of the kits before they all go. Did you get my email ok? Would love to do this project
Le Roux said:Jim50hertz said:- unsure how the polar pattern switch works, what are you guys using, normal SPDT?
I'm using a Lorlin.
Must you use a switch?
Or can you wire direct?
Jim50hertz said:The switch changes the polar pattern from cardioid to omni. One could hardwire if one wanted only one polar pattern, i.e. cardioid only.
Or am I misunderstanding your question?
Winetree said:OK,
Just got my Skylar Mic Bodies and went back to the first page for assembly.
The body is different in the examples. Where are the brackets to mount the P.S.B in the rails?.
Do I still mount the white risistor to the base and extend the wires or let it hang
there's plenty of room.
Winetree said:Just put Skylar's mic body in Ben's case. Tight fit.
Had to notch out the dense foam on one end for the mic connector end.
Now I can't close the box. Too much top and bottom foam.
The foam is too dense to compress.
Anybody dealt with this yet?
bobine said:Just finished the mic. First listen: wow, this sounds really nice.
MK47 with Beezneez capsule in EQU47 body.
Huge thanks to all!
