micaddict
In76d wrote:
AFAIK the 6028 is basically a "hotter" version of the EF95 or 6AK5.
There's an 18AK5, too (Vf 18 Volts).
Yes, it's typical for 6028 - i don't know how those tubes can be considered as related to VF14.
Specs are different. Good that many folks like it, but is it anyway close to U47?
You readings are fine for 6028. There 's no option to get real U47 specs here.
For plate is correct, for polarisation - yes your multimeter input impedance is too low, for heaters - it should be a little underheating. 40V was a big underheating for VF14. To get similar result (in theory of course) for 6028 you should get around 13-14VI doubt that these tubes can work with that low heater voltage.
