Hi
I have had this dj mixer for so long and honestly out of all the mixers I have played on, it's still the most pleasurable and smooth one to play on!
Only one annoying problem...
When you set the gains for a certain channel to 0db when cueing (pfl), it comes out as +6db on the master when the fader is fully open. This is a problem because as a dj you try to keep the levels out of the red and like this you don't really have full control over the levels.
I was wondering if adding 2 resistors (stereo) in series with each channel fader would do the trick. Just lowering the general signal so +6db will actually be 0db. I have attached a picture of the mixer.
Would there be any problems doing this mod?
Kind regards!
Kind regards!
