Svart
I just received my Echo MIA in the post today and was checking out the circuitry.. of course I got the box open and immediately started looking for something to mod... :green:
Well, it has a few electrolytic coupling caps.. 47uf.. It also uses JRC NJM2068 opamp.
Comparing the 2068 to the 5532 (pin compatable), the 5532 shows better slew rate as well as better numbers at other tests like unity gain bandwidth, etc.
so my question is.. do I change the 2068 to something better and give it a try? The current consumption of the 5532 is twice that of the 2608 however I have noticed a to-220 Vreg on the pcb, as well as another smaller SMD vreg but have not traced out where the opamps source their power from yet.
should i try something from Burr-Brown? My Tascam mx-2424 uses the exact same AKM converter as the one on the MIA but uses OPA134 opamps..
so in a nutshell, I would like to change the coupling caps and the Input Op-amps. (output opamps can stay for now) any suggestions for the products to try? I would like something with a clean sound. any powering/decoupling issues I will deal with once I get an idea what i need to power!
thanks!
:guinness:
thanks!
:guinness:
